Browse Forums General Discussion Re: Timber flooring 2Oct 30, 2006 6:19 pm Your local supplier should have some contacts they can give you. Re: Timber flooring 5Oct 31, 2006 6:56 am Are you talking about solid timber flooring or 'floating' floor laminates?
Let your fingers do the walking......yellow pages Re: Timber flooring 6Oct 31, 2006 11:07 am For 8 mm laminate we got ours from Premier Home Furnishings which is based in Perth. They did us a pretty good deal and they can do laying for $20 per square metre. We ended up getting them to do it cos we are hopeless at DIY and they did a marvellous job. Give Adam a ring on 0431931981 Re: Timber flooring 7Oct 31, 2006 4:10 pm If you want real timber, I have been told that Perth Timber Flooring in Mt Lawley are the best. Their quotes were very competitive and they have an excellent reputation for workmanship. What you have to look out for is that some flooring suppliers will outsource the laying/sanding to independent contractors, so if there is a problem with the workmanship you can't just go back to the supplier. I know that Perth Timber Flooring do the whole job "in house", so you won't have a problem with this.
Good luck Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6454 |
