I'm looking to install a gyprock ceiling. My roof trusses are spaced at a whopping 1600mm. Any advice on steel channel or timber battens that won't sag with that span would be appreciated. What size and spacing?
Plastering Ceiling advise please
Have never seen trusses spaced that far apart before.
Are they timber trusses?
I would suggest you will need Intermediate Ceiling Joists and binders to close the spacings up for any batten to have a chance of working.
Similar to that suggested above, I suggest timber hanging beams (120x35 MGP10) at 1200mm centres and then light gauge steel ceiling battens fixed to the hanging beams or ceiling joists depending on the depth of the bottom chord of the trusses.
1) Upload your photos to an image hosting site like Photobucket.
2) Click on your photo that you want to post here.
3) Locate the IMG tag under "Share Links" on the right hand side of the photo.
4) Click on that IMG code line and copy it.
5) Paste that into your post here then hit the submit button.
Stewie
If you don't know who the designer is, then one should get a structural assessment done as the weight of plaster board is significant
Stewie
As others have said, plasterboard and insulation add weight to an already
designed/engineered minimum standard because of costing.
If it was my shed,I would increase the loading capacity of the trusses.
This can be achieved by cladding both sides of the truss with brace board
glued and nailed to the cords and webs,effectivley making a solid truss.
You could then batten screw 90x35 or 90x45 on its flat to the underside
of the bottom cord @ 600c to take the plasterboard.
Of course,run this proposal by your engineer.
by a draftsman
or else be
9
If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify…
23/08/2023
I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps…
17/06/2023
How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity?
