Browse Forums General Discussion 1 Jul 19, 2015 1:40 pm Hi Guys, Just a quick question because I'm a bit confused and don't know who to ask. According to my subdivision plans, we have a 3m easement at the rear of my block. We also have a building envelope that ends 3m from the rear my block. From what I understand, a building envelope is the area that we are allowed to build in and the easement is water and sewerage pipe locations that we have to be a certain distance away from (usually 1m). My question is, why would my building envelope end directly on top of the easement if we have to be a certain distance away? thanks! Re: easement Vs building envelope help 2Jul 19, 2015 2:22 pm Different organisations look after the different aspects. The easement is normally an issue for the sewerage authority. The Building Envelope is an issue for the planning authority. You don't have to be a particular distance from the easement. You just have to be building outside the zone of influence of the pipe (see http://www.anewhouse.com.au/2012/01/bui ... -close-to/) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: easement Vs building envelope help 3Jul 19, 2015 2:29 pm thanks bashworth, I was actually on your website yesterday. I actually don't know how deep the pipes are so it is hard for me to determine the zone of influence. I do know that my builder has drawn plans that have my house situated 110mm away from the easement line. It concerns me a bit. Do you know where I would obtain the exact locations of the pipes below the easement line? Re: easement Vs building envelope help 4Jul 19, 2015 2:37 pm To get the exact location the water authority can peg out the line but there will probably be a charge. They should be able to give you a depth if you tell them the title details The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: easement Vs building envelope help 5Jul 20, 2015 8:57 am If you are outside the easement the depth of the pipes won't matter ( as far as Sydney Water is concerned ). The easement width is generally so the water authority can access the pipe with men and machines. The fee from memory is about $300 but if you take your plans to a Reece Plumbing outlet they can look up your site of their database. If you are outside the easement or their ZOI then they should just stamp your plans as approved - no fee. Stewie Re: easement Vs building envelope help 6Mar 04, 2016 12:16 pm mitchiib thanks bashworth, I was actually on your website yesterday. I actually don't know how deep the pipes are so it is hard for me to determine the zone of influence. I do know that my builder has drawn plans that have my house situated 110mm away from the easement line. It concerns me a bit. Do you know where I would obtain the exact locations of the pipes below the easement line? mitchiib, did you end up getting the info about the depth of your sewage pipe? and find out the zone of influence to the depth of the sewage pipe? You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17163 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3373 |
