Browse Forums General Discussion 1 Jul 15, 2015 8:33 pm Hi, I'm looking for a bilge pump that has discharge upto 15m head. Some of the companies that I looked at are Seaflo (3700gph, 12V) and Rule (4000gph, 12V). I plan to connect this to solar power and float switch to pump water into my home water tank (three-storey around 15m head). Has anybody had an experience with these pumps? If yes, what has been their performance overall (reliability, water discharge as expected)? Would be good to know other reputed bilge pump manufacturers as well. Thanks! Kushal Re: Bilge pumps (experience and recommendation) 2Jul 15, 2015 9:06 pm I would say that bilge pumps won't be up to the job as they are meant to operate at a fairly low head (typically 1-2m) Looking at the Seaflow pump data they seem to have a maximum head of 8m. Although the Rule pumps don't supply the same level of data I would expect a similar maximum head to the Seaflow pumps. if you want a solar powered pump I would suggest you look at borehole pumps which are designed to pump at higher heads. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15165 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 15079 |
