Browse Forums General Discussion 1 Jul 08, 2015 11:19 pm Hi guys, I am looking at buying a fibro home at the moment. The is no garage on the house so I am thinking of adding a garage on the end of the house using your ordinary steel frame kit garage but following the house roof line and attaching to the house. I want the house and garage to have the same finish so it doesn't look tacked on so I was thinking of using 'blueboard' or a similar product to clad the garage and redo the house cladding. What product would be best for this? I am looking for a flat finish (smooth or textured) as in no visible joints between the panels. Am I going to have to have some sort of flexible joint between the house and shed/garage to allow for movement between the 2 structures? Any advice or differing ideas are welcome. Re: Blueboard as shed/garage cladding? 2Jul 09, 2015 11:01 pm James Hardie Blueboard with an acrylic modified cementatious jointing compound (DULUX ACRATEX ACRAPATCH SYSTEM) followed by an acrylic texture coating system would be your best bet. http://www.dulux.com.au/media/429801/du ... 0guide.pdf The final finish can be from a trowel on, roll on or spray on application. http://www.dulux.com.au/specifier/our-b ... s--systems This is really a professional trade and requires training and a bit of experience to get looking good, but there are countless plasterers who can do it for you. Best bet is to go into your local dulux trade centre and see if they have some business cards for local dulux accredited texture applicators. These are the only plasterers/painters qualified to do the job properly. Where the shed joins on to the house, there will be an expansion join, your plasterer should be able to supply this. Do not DIY this. DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 8753 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5417 |
