Is there anywhere i can do a search to find out if a particular property has had or does have a septic tank installed?
Cheers
Browse Forums General Discussion Re: septic tanks - can i search? 2Jul 08, 2015 4:45 pm Check the sewer records for the local water authority. No sewer and they should have a septic tank or other on site treatment system. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: septic tanks - can i search? 3Jul 08, 2015 8:32 pm Trying to find historic records. I know the neighbours on one side pulled one out but not on the other. House is in an area that had tanks till the 60's. Recon I could get that from the local water authorities? Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: septic tanks - can i search? 4Jul 08, 2015 9:25 pm If a sewer went through the area it is normally for the water authority to record details of septic tanks to prepare for connection, even if properties don't initially connect. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17287 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15019 |
