Browse Forums General Discussion 1 Jul 07, 2015 8:24 am Hi All I'm currently trying to finalise my kitchen selections and wanted to know if anyone can explain the difference between Ultraglaze and Createc? I am wanting a high gloss look for my kitchen and the quote I've received from 2 different people (one works with Ultraglaze, the other Createc) has been vastly different. Ultraglaze being the cheaper option. Difference? Pros/Cons of each? Thank you! Re: Kitchen Help Needed 2Jul 08, 2015 6:58 pm Ultra-glaze doors are very high gloss acrylic sheet laminated to a board and then cut and edged in matching edging. The surface gives a mirror gloss finish and you can choose from more than 20 different colors. Ultra-glaze pricing is similar to polyurethane, but cannot have a routed face. The acrylic is now reasonably scratch resistant but must not be cleaned with an abrasive cleaner. You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15610 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 |
