Attic conversion in WA - anyone here done this?
Seeing how the roof frame is constructed has made us think that there might be a decent space for an post handover attic conversion in a particular spot in the house.
We have a friend who had done an attic conversion to his current house (cost ard $10K), with insulated sheet walls, flooring and ladder. I've been up in that attic, and while it is a great use of additional space, I can't seem to justify the $10K cost for that conversion?
Is there anyone here that has done an attic conversion for storage purpose that would care to share their experience?
Thank you
There are a few things to consider too especially if it is an existing trussed roof. See here for a few pointers...
viewtopic.php?f=3&t=74787
viewtopic.php?f=53&t=67539
Stewie
How many m^2?
$16 manhole cut in
$100 or so on marine ply
about 5m2 of storage
Jobs done
Also installed a whiskey bird to take heat out in summer and it was the best $2k spent.
Wild Turkey ?
If all you want to do is store your christmas decorations up there with a box of your plastic camping gear then the cheap version of a couple of sheets of pineboard thrown over the existing bottom chord of the trusses and a manhole in the ceiling is fine. Anything more substantial and you'll spend a lot more as per the ones we've done otherwise risking bowed ceilings and worse.
Me too Perth_Euro ???? At least it would make your ceiling space smell nice !
Stewie
For a living area as such, there's a lot to be done, as one of the first things to ensure is that ceiling can support all the extra weight that it now needs to support, without causing you all sorts of other issues.
I know my new home won't support much extra weight up in the ceiling, however it will be fine if I spread the load and ensure it isn't heavy stuff.
They have to saw the structafloor into manageable pieces that fit through the ladder hole.
Mate of mine got a 20sq meters dust free conversion for about 10k from memory
We made life easier for ourselves by erecting a quick stage aluminium scaffold next to the roof then removed roof tiles and sarking between two rafters to pass all the sheets up from the ground then through to the new attic space.We only had to cut pineboard sheets and gyprock to length and saved ourselves a bit of extra work. Then all we had to do after we finished was replace and lap the sarking in that area the re-lay the roof tiles we had removed.
Stewie
Unfortunately I don't know much about the specs about our friend's attic. I saw it at the time when we hadn't even considered building or weren't quite interested in attics yet. Maybe I'll have to pay him a visit again soon lol...
We have just had a storage attic installed in Caversham. We used andy from A1attics he was very competitive on price and open to my ideas. We also had a whirly bird installed to extract some heat from the roof space works amazingly. Its great to have some space back in our spare room. cheers
2
From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between…
22/01/2024
Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and…
27/02/2024
2
Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold…
