Browse Forums General Discussion 1 Jun 10, 2015 1:16 am Hey all We tried to move our niche as we decided on a shower head with a pole. Not sure of the technical name for it if it has one. The problem is the pole runs through the middle of the niche. Still plenty of room to use the niche just don't know if it would look silly? Should i just do shower head without the pole? Re: Shower Pole Over Niche 2Jun 10, 2015 7:05 am Yeah, it would look a bit like a mistake was made in my opinion. By pole I assume you mean a sliding rail so you can adjust the height of the shower rose by sliding it up or down? If it is a fixed height rose I'd just choose another that comes straight out of the wall. Stewie Re: Shower Pole Over Niche 3Jun 10, 2015 5:31 pm If it is the hand shower part you are after not the pole you could have one just on a bracket like this one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: Shower Pole Over Niche 7Jun 11, 2015 8:50 am Yeah, some of those posted above do look very swisho. Until the OP posts up a pic of the shower enclosure or tells us the location and size of the actual niche involved then I guess most of our suggestions are moot. Most recesses/niches in showers from what I've seen vary from 300 x 400mm high to a lot bigger so.... Stewie Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8359 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1815 |
