Browse Forums General Discussion 1 Jun 09, 2015 6:41 pm Hi Guys We just recently built a new house, we had the house rendered… the render with paint colour already mixed in it (white) as the house sat for a while, while it was getting built, the white turned brown…. So we are getting the house painted, the painters are using Dulux weather shield… They have done 3 quotes so far, but i can still see the roller marks in some areas… what is the best way to minimise or get rid of the roller lines/marks… more coats? Re: Painting Render... 4Jun 22, 2015 1:11 pm Some colours need to be done one wall at a time & FAST to avoid uneven dried finish. If it's being applied correctly i'd be contacting Dulux & having them send a rep out to take a look.. Re: Painting Render... 6Jun 22, 2015 6:26 pm I have Dulux Shale Grey and I too can see some roller marks, but not extremely noticeable so am living with it for now. Inside paint job I am getting rectified though Dale - Building Newbie Proserpine, QLD Re: Painting Render... 7Jul 01, 2015 7:23 pm Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? Re: Painting Render... 8Jul 03, 2015 7:11 pm To avoid roller marks each wall must be painted (including cutting in) whilst the wall is in shade. That is what I learnt (the hard way) on my build. I started painting over the Christmas/New Year break i.e. mid summer and had to repaint the entire house, inside and out once it cooled down a bit. Re: Painting Render... 9Jul 10, 2015 5:35 pm rocksteady Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? They said they would try and fix it but also blamed a bit of the render work?? Re: Painting Render... 10Oct 21, 2015 9:17 am Jason007 rocksteady Jason007 Thanks for the reply guys, its Dulux Shale Grey…. and in some areas I can see where they have cut in... What did the painter say about it ? They said they would try and fix it but also blamed a bit of the render work?? Sometimes you need to sweep away the loose sand but once you seal it (bondcrete) it's out of the renderers hands, unless chunks of render are falling off or the surface is not flat, they have done their job & cant be blamed! Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5068 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8286 |
