Downpipe in cavity?
Page 1 of 2
Is it alright if the builder is installing downpipes into cavity? Especially with zero boundary garage walls nowadays, I am guessing there isn't much of a choice? Also, if there needs to be downpipes on the front facade, then surely it will look better if they are in the cavity wall?
However, how would you find out if something is wrong with the downpipe further down the track? By the time you do find out something is wrong, the damage that it has caused is probably pretty extensive? What are the problems that could occur?
Cheers!
As you mentioned, what happens when it clogs?
What happens when you get a large downpour and your downpipes can't cope and overflow?
I would not ever put a downpipe into a cavity.
Zero lot houses generally don't have a downpipe where the boundry is, they put it somewhere else.
Can you always avoid it though? I am not sure if you can always put it somewhere else. For example, if the length of the boundary wall is 9 meters, I don't see how they would avoid it. Do they slope the roof to one end and have 3-4 downpipes on a wall that side?
A zero lot wall with a large roof area draining too it should have a box gutter that runs to rainheads at either end.
With regard to running downpipes in a cavity:
Our portico is made from recycled bricks. I didn't want a downpipe for the small roof to be visible so I ran a rectangular pvc downpipe inside the pier. I wouldn't conceal metal downpipes in a wall because eventually they will rust out and then they are impossible to replace. Its discrete and works a treat.
Many commercial buildings have internal downpipes so it's not a big deal. The water doesn't escape the downpipe when its PVC and glued up, it overflows at the gutter, which can be a problem when you have an internal gutter as with zero lot walls.
Good luck
I do not think installing a downpipe in a cavity is a good idea at all.
Zero lot houses generally don't have a downpipe where the boundary is, they put it somewhere else.
When it clogs, you clean it just as you would any other downpipe???
When there is an unmanageable downpour it behaves just like any other overflowing gutter, into the eaves or cavity.
Downpipes are sealed to gutters and have nothing to do with the results of overflow issues so I'm not sure what your point was here????
multi story buildings run plumbing (faecal matter and urine!!!) through cavities and we don't have concerns, how should this be any different
I wont sit here and be an armchair expert but I'm pretty sure where the downpipes are routed should be the least of your worries.
Worry more about the amount of drainage in total, that is where problems arise.
just use round downpipes instead of rectangular and they look much better.
You have a square line gutter along that garage wall and as noted on the plans they are putting in a rainhead at both ends as I suggested earlier on. You can't hide the rain head so there's no point trying to hide the down pipe.
I didn't realize that the rainhead can't be hidden. Is there really no way to hide that whole piece?
Stewie
Just about every double story house in WA has the identical set up.
My house is exactly the same. Get a nice rain head and use round downpipes and they look fine.
We may differ in opinions but like the OP I think downpipes and rainheads look like crap. I'd hide as many of them as possible on any house by a bit of good pre-emptive design. Like vertical drainage stacks from upstairs bathrooms.
Stewie
You'll notice that the portico has a pvc downpipe inside the pier and that's what the op was obviously trying to do with the garage down pipe.
That section of the garage will also have downpipes from the second story feeding on to it. Personally I'd be doing the roof differently to the way it's drawn, but that's the cheapest way to do it and rainheads are the only option with the way it designed to be constructed.
It's just doesn't happen here in WA. It's drawn that way for a reason.
Maybe over east you have more options to run downpipes internally but with double brick and suspended slabs it's a different kettle of fish.
Stewie
Absolutely agree with the plumbing stacks. I think the days of running plumbing down the outside of buildings is long gone. It looks so ugly.
There is no cavity to hide the down pipe in. It's a garage pier that is structural. It's holding the lintel and formed concrete beam for the upper floor.
The house has not been built yet. We are at pre-start stage. Currently the drawing shows no cavity but can't the cavity be created just like how they did it to the garage wall on the left where a cavity downpipe is there as well?
And to add to the difficulty of running the downpipes internally would be the need to core drill the second story slab.
Why do you have to drill the second story slab when there isn't a slab directly above it? The builder did notify me that the variation item is done but I have yet to get the details and the price of the variation. I will post it once I get it.
I guess if has already been built then to retrofit an internal downpipe as I say would be a lot harder than if it was still at the design stage. Core drilling the existing slabs etc as you say would be a pain. The few double brick homes with concrete slabs I've worked on before have had a couple of internal stacks one for sewer and the other two for downpipes and if they are designed right at the start they can be hidden. It depends how much of an issue the owner has with downpipes at the front of a house and how keen the builder or his designer are to accomodate them I guess.
Stewie
Stewie
I am currently finalizing my pre-start and will post what the builder proposes.
If the house is only at pre start then it is achievable but they will have to make provision for it by having a penetration through the slab and a small stack in the front corner or running the cavity wall all the way through to the front of the garage.
I would be interested in what they are going to charge you to do this.
1
It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single…
23/02/2024
3
Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you…
