Browse Forums General Discussion 1 May 24, 2015 3:16 pm Hi all. We would like to paint the ceiling in our coastal-themed home white. It is pine-lined with beams all the way through. Has anyone else done this before? We are on a budget. Is spraying the ceiling an option or is there more work involved in this type of project? Re: Painting pine-lined ceiling with beams 3May 26, 2015 9:40 pm if it is pine lined, it is probably coated in a varnish. This will cause adhesion problems, so a light sand and a coat of acrylic primer would be a good idea before attacking it with top coat. for this particular ceiling avoid ceiling white, it will breath a bit much and possibly let moisture break down the coating because of its inability to disperse through the pine. for this reason use a higher quality top coat. All in all probably the easiest thing would be an exterior self priming low sheen acrylic, which negates the need for a primer! Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 14065 THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28778 |
