Browse Forums General Discussion 1 May 24, 2015 1:11 pm Hi all, I am looking at a putting some basic lining / insulating my shed roof. The height of the shed roof is quite low, 210cm dipping to 195cm. In order to maximize the space (height), i was thinking of attaching some polystyrene sheets to the underside of the shed roof with an adhesive. Interested to hear your thoughts? Cheers, Robbie Re: Insulating a shed roof with polystyrene 2May 24, 2015 2:31 pm Have a look at Foilboard , easy to work with. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulating a shed roof with polystyrene 4May 26, 2015 6:20 am robbie_p Thanks! Can it be attached directly to the roof of a shed? Yes you can either cut in between rafters or just go across bottom of them and screw or nail the board. Also you can tape seal joints or edges . It comes in various thicknesses and indeed is a very good product that is easy tot work with and efficient. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulating a shed roof with polystyrene 6May 26, 2015 10:21 am robbie_p would i still need to try put in some anticon? If you are only insulating a shed no. Anticon blanket insulation is usually applied over rafters and battens, this means you would have to take roof sheets off. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Insulating a shed roof with polystyrene 8Jun 01, 2015 1:20 pm Due to the low roof in the shed (2100-1950mm), I dont want to waste further space by using ceiling batts, so I'm looking at using 30-40mm polystyrene, with an additional layer of foil between the polystyrene and shed roof, then tape sealing the joints and edges, then adding some trimming to neaten things up I'm going to need about 4 sheets / boards of polystyrene, each about 1800mm x 1250mm, which are about $40 each (cut to size)) Re: Insulating a shed roof with polystyrene 9Jun 01, 2015 2:10 pm Just remember, foil insulation is only good for radiant heat, so if going to put it ontop of the polystyrene you should have some gap in between or the heat will be conducted past it. Also best to have a 10-20mm gap between your roof sheet and the Polystyrene. a 50mm Polystyrene sheet will have an approx. R1 value, this does change depending on the density of the Polystyrene. as the say...oils aint oils same applies for Polystyrene but the manufacturer will be able to give you data. Re: Insulating a shed roof with polystyrene 10Jun 01, 2015 2:15 pm Thanks, I can keep a 10-20mm gap between the Polystyrene. Does 50mm Polystyrene only have a R1 value? I thought it would be higher than that? I think i read somewhere that the standard for roofs is around R 4? Re: Insulating a shed roof with polystyrene 12Jun 01, 2015 2:50 pm I think ill go with Foilboard (25-30mm), as mentioned above, with a 10-20mm gap would be a good idea.. i think Foilboard works out cheaper than polystyrene (which i didnt know) Re: Insulating a shed roof with polystyrene 13Jul 22, 2015 10:27 am robbie_p I think ill go with Foilboard (25-30mm), as mentioned above, with a 10-20mm gap would be a good idea.. i think Foilboard works out cheaper than polystyrene (which i didnt know) I think you will find foilboard is polystyrene inner with a foil face. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5404 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3423 |
