Browse Forums General Discussion Hi all, I am currently building through Simmonds and stuck deciding on my exterior cement roof titles and brick colours. The front and fascade of the house is a pretty… 0 2730 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8510 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12052 |
