Knowing Your Rights...
So in relation to building and more importantly (to me), issues related to covenants, I have created a list of useful links.
You can view this list (mostly based on QLD builds) on my blog here:
https://retreatinstyle.wordpress.com/know-your-rights/
Hope this list of resources helps others to at least gain the correct information.
A most basic place that people should start is with the Guide to Standards and Tolerances. This document, which is state dependent, is a summary of the things that any consumer should be able to pick up for themselves.
QLD: http://www.csq.org.au/csq/media/Common/ ... eguide.pdf
VIC: http://www.vba.vic.gov.au/__data/assets ... s-2015.pdf
After these documents comes the "juicy" stuff (i.e. the real regulations). These are where the real rules are documented but involved reading many thousands of pages...
1. National Construction Code - https://services.abcb.gov.au/NCCOnline/ ... tions/2015
2. Australian Standards - http://www.standards.org.au/Pages/default.aspx\
3. Manufacturer guidelines - specific to each product in your house
4. State specific requirements - refer to your state's building commission (or similar body)
Thanks for your addition of more useful links.
I don't recall ever mentioning that my list was a exhaustive list or that it was the only material worth reading. It is merely a start and as I DID mention, is more aimed at specifics that I am interested in (covenants).
My condolences for the loss of your house. I guess with or without my list of documents your house was demolished so in the end your were still a sitting duck.
Some alternative food for thought..
The building code and Australian Standards are awesome reading. I have complete collections of both. (Ex draftsman). They will help immensely with construction methods. They won't however, do jack 5hit for you on the side of law. Legislation will.
Between the two of us we can provide people with enough reading for years
My house was demolished by our builder, which thankfully means that apart of the hassle of seeing everything go pear-shaped I don't have to incur anything other than waiting for an additional 12 months.
4
The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone…
12/11/2023
13
Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini…
25/09/2023
2
Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their…
