Removing steel post to open up alfresco
Page 2 of 2
I don't understand the reticence shown by the draftie if you are willing to pay for it ????
Stewie
I don't think boxing down for the beam would be much of a probem visually though, given that the ceiling ends along that line anyhow, as it goes up to double height over dining.
Stewie
The other thing you would need of course is two other beams at 90ยบ to this main one. One over the Family/Outdoor Living doors and another where the upstairs void starts at the Kitchen/Dining junction both to help support the joists for the floor above.
It's all pretty much a moot point as it sounds like the OP can't even get the draftie to look at it let alone the builder to cost it...
Stewie
Similarly for the doors. It doesn't matter how high you have them. If you want less of the beam showing then you'd continue the door frame right up to the beam but then what do you do for all the rest of the door heights ? I think it would look odd just to have one set a lot higher than the others unless you want to fork out the extra to increase the height of them all on the ground floor.
The air con ducting and vents are the other things you'd have to consider for sure.
Stewie
I know nothing about building but after a few episodes of grand design where houses are seemingly built of glass, I know that post is removable for the right price and you've all confirmed that so thank you!
Thanks Stewie! It's re-assuring to know that my builder has also given me all those different senarios as well to think about aesthetically.
He has also suggested an exposed beam look, if you don't want the gyprock around the steel beams and go for an industrial look.
Its not up to the draftee to tell you its unable to be done.
The engineer designs the correct beams.
Engineer specified 310UB & 310UC and used 410mm floor trusses to have no bulkheads. But did cost extra how much unsure.
I would push back if you want this as you are paying him to draw it to your specifications not his.
Just some info for for cost wise, we opened up our alfresco (was an option with the builder they had no probs removing the post if you are happy to pay) but it cost about $6300 but that is a one storey house. Our frame is only just going up now so haven't seen the end result yet but it should look just like the display home we saw. We have 2700 ceilings and stacker doors.
Just an update for everyone that offered their much appreciated advice... Tender back completely ignoring this. No comments, explanations, nothing. On top of that they say they also can't sink the media room or provide tiled wastes to the bathrooms (among other things).
I'd be looking for a new builder if I were you. It's not that they can't its clearly that they don't want too. Makes you question their ability to build a house
We also want one of the asymmetrical baths that peak at one end, and they won't even rotate it the correct way around- surely they can just run the pipes an extra 50cm!
Media room- apparently it is 'impractical' to sink a room in the middle of the house and may also cause waterproofing issues... Tiled wastes in the bathroom- apparently they would need to raise the height of the room to enable this, leading to a big step up to the wet area.
Can't have higher stacker doors to family room and dining due to the deep beams above. Who knows. Tired of thinking about it! Even scarier to think we are basically back at square one looking for a new design after a year of dealing with this company
Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am…
7/03/2024
2
That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel
22/08/2023
1
Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution…
