Browse Forums General Discussion 1 May 05, 2015 12:29 pm Re: New Wall cladding product. 2May 22, 2015 11:34 pm There are similar panels here with foam, fiberglass, fibre cement sheets and magnesium oxide panels I haven't seen those exactly with what looks like hay or wood substrate type of eifs: http://en.m.wikipedia.org/wiki/Exterior ... ing_system Plenty of companies here make it, masterwall, zego depends on how sting you want it we are using magroc panels for or whole house 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: New Wall cladding product. 3May 24, 2015 12:49 am Is it modcell? There's a old way of making cob houses something like that were they mix straw with a bit of mud and push it into temp walls till dry then remove walls and render over, cheers Lorri Re: New Wall cladding product. 5Jun 06, 2015 10:56 pm Looks like it might be wood wool boards: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ https://www.lime.org.uk/products/boards ... ol-boards/ Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4480 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12045 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11116 |
