Might seem like a silly question but I can't find double entrance doors anywhere. Should I just be looking for single entrance doors and getting two with one being deadbolted?
Thanks
Browse Forums General Discussion Re: Are double entrance doors just two doors? 2May 03, 2015 10:33 pm corza000 Might seem like a silly question but I can't find double entrance doors anywhere. Should I just be looking for single entrance doors and getting two with one being deadbolted? Thanks That's pretty much it. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Are double entrance doors just two doors? 4May 04, 2015 10:21 am Yes and no. For a pair of doors to be water/draught proof where they meet they should each really be rebated. You can still use just a couple of normal doors as a pair but unless you have the rebating it'll be a drafty house seeing as you should have a gap of 3mm or so between them. For these doors also you need to have the proper rebated door lock set. Stewie Re: Are double entrance doors just two doors? 5May 05, 2015 7:52 pm Stewie D Yes and no. For a pair of doors to be water/draught proof where they meet they should each really be rebated. You can still use just a couple of normal doors as a pair but unless you have the rebating it'll be a drafty house seeing as you should have a gap of 3mm or so between them. For these doors also you need to have the proper rebated door lock set. Stewie Hi Stewie, I've seen plenty of builders and pre hung door suppliers over the years use a mushroom mould (the "T" piece one) to create a seal without the need and expense of getting the doors rebated. I have bought standard doors myself and cut my own 20mm x 20mm rebate on the edges. It works out heaps cheaper than getting a custom set from the joinery as you can use one of the standard range of bunnings doors which are pretty cheap in comparison. As a side note, anyone going down the rebated door track needs to be mindful that once doors have a rebate cut on them they become handed so the rebate on the left door is on the opposite edge to the right door. Unless they are a flush panel door you need to make sure one of each edge is rebated As for the rebated door lock, you can actually buy just a rebate kit which allows you to adapt any typical door lock to work on a door rebate Also, if you didn't have a mushroom mould or rebate they wouldn't be secure as someone could reach through the gap with a credit card or similar and flick the latch Re: Are double entrance doors just two doors? 6May 05, 2015 10:36 pm I agree 33amc about the need for a seal but I still like a proper rebate over a third party mould. I've seen both the Tee mould and also a z flashing but I never really liked them. It just comes down to personal preference. Stewie The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16240 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20935 |
