Browse Forums General Discussion 1 Apr 25, 2015 4:09 pm Hi there, I am new on this forum and have a particular question that I have not seen before. We purchased our house 2 1/2 years ago, the owner subdivided the block, putting a fence on the new boundary line. There is a pool in the back yard and when the new fence was put in the pool pump and filter were moved which required new wiring and plumbing for the pump and filter. I was removing a plant from the garden and found the filter outlet pipe and wiring conduit laying on top of the soil, buried only by a layer of leaf litter and bark. The conduit goes about 3 metres through the garden then is travels along the fence to the pump. Where the conduit comes from the house you can see where the previous conduit was buried under ground (right under the new conduit). This situation was obviously not picked up in any of the pre-purchase inspections. My question is this, do we have any comeback against the previous owner for this and getting the situation rectified. Thanks, Re: Found power cable in garden laid under bark (in conduit) 2Apr 26, 2015 10:30 am I think you'd be pretty much out of luck, as your pre-purchase inspection failed to pick it up. You're just going to have to get a sparky to come in and reinstall the cabling in a 600mm deep trench. I'd suggest you arrange the trench dug yourself, as your sparky will charge you at his rates to get it done, but speak to your sparky first so you know where he wants it dug from and to. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Found power cable in garden laid under bark (in conduit) 3Apr 26, 2015 11:37 am what colour conduit orange is 240v and higher grey may be low voltage for garden lights or irrigation system or pool lights the conduit may be disconnected but may have been left in the ground due to laziness as mentioned probably best to get electricain to test and see if it is still in use the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2860 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8100 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15836 |
