Browse Forums General Discussion 1 Apr 20, 2015 10:19 am Good morning, I'm building a new house in Penrith 2750 NSW as a battle axe block that will be strata titled once completed. I have a query, our council stamped plans has a private power pole for the electricity but the builder has told me today that for strata title you have a joint power box with separate meters; is this correct? What it will mean is instead of having the private power pole, the electrician will upgrade the power to the front house, then run the power under the front house (clipped to the bearers and joists) and then the power will be taken to the new house at the rear. I'm building with a smaller project builder. Any advice would be appreciated as it does not seem right. Kind regards, Peter To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10947 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4582 |
