Browse Forums General Discussion 1 Apr 14, 2015 9:03 am Hi all, We're building a side-by-side dual occ in Caulfield VIC (Glen Eira council), with centralised crossover proposed. We've got the planning permit issued, but being the end customer and not familiar with how it works, going forward we're actually wondering who can actually do such work? On top of that, being in the permit conditions, we also requested to relocate the water drainage side entry pit and a small tree (quoted by council for $600 odd to just remove and reinstate it!) on the nature strip affected by the proposed crossover. My understanding that these all are council's or the responsible authorities assets, but are we to get someone like a concreter or plumber to do such work? Or can we get council to inspect and quote the job for us all up? Our builder advised that we complete the side entry pit relocation work first before they can commence the construction, but I guess, correct me if I'm wrong, it's not only a matter of relocating the side entry pit itself, as it also involves the vehicle crossover relocation/reinstatement which will need to be done at the same time? Appreciate all your replies, thank you! Cheers Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9505 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6328 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11348 |
