Browse Forums General Discussion Re: What is this pipe used for? 3Apr 04, 2015 5:06 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: What is this pipe used for? 5Apr 04, 2015 9:19 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: What is this pipe used for? 9May 01, 2015 3:32 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: What is this pipe used for? 11Aug 23, 2015 1:01 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 17384 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 5303 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 3247 |
