Browse Forums General Discussion 1 Mar 19, 2015 7:57 pm Hi Everyone, I'm building a new house, 3 bedroom, about 150m2 (or 16sqs). Thanks to this wonderful forum, I got onto the idea of sarking and my builder is going to include it in my new house for only $740.00 But then I read if you have sarking, you need adequate roof ventilation. At first I thought this applied to colorbond roofs only, but now I think it's also important for tile roofs. My roof is going to be Boral Concrete Tiles with sarking. Do I need roof ventilation? How much do I need? Will a couple of whirlybirds do (builder quoting $600 for 2)? What about eave vents (because I don't have any eaves)? And do I need ceiling grilles? And can I do this stuff after the house is built, or does it have to go in now like the sarking? And what would be a good price from the builder? Please and thank you Re: Whirlybirds & Roof Ventilation - Do you need it? 2Mar 19, 2015 9:31 pm My previous house built in 2001 had sarking and black tile roof with zero whirlybirds. Our current build according to council requires 5. Our quote had only 4 and the builder charged an additional $150 for the extra whirlybird. Re: Whirlybirds & Roof Ventilation - Do you need it? 3Mar 20, 2015 10:22 am aloenyx ..if you have sarking, you need adequate roof ventilation... Don't think so - in a cooler climate (like Melbourne) your home will perform better with an unventilated roof (in NatHERS, anyway) Small footprint in Eliza Ponds, Spearwood WA Re: Whirlybirds & Roof Ventilation - Do you need it? 4Mar 20, 2015 10:48 am A better idea is a electric extraction like Maestro then you can set it on thermostat for extraction at appropriate times and temps. Maestro is equal to about 3 whirleys. Re: Whirlybirds & Roof Ventilation - Do you need it? 5Mar 20, 2015 9:43 pm Thanks for the responses. Don't think my estate will allow whirlybirds. I'm thinking the easiest thing will be to do nothing while building (since its just one more thing on the mortgage) and then once I've moved in, look at a range of options. My builder's options are quite limited and from all reports, I can retrofit a bunch of different options. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 5474 Painting your colorbond roof with a rust inhibitor can definitely help extend its life and prevent rust. It is worth the cost in the long term as it may be cheaper than… 1 747 |
