Browse Forums General Discussion Re: Hebel external aging 2Mar 18, 2015 10:06 pm Hello, may I suggest you call the Hebel 1800 number for their call centre. They'll be able to point you in the right direction. Several of the bigger project builders are using Hebel more often. Bear in mind all Hebel external walls must be rendered. So, you can invest in a great walling product, but it will only look as good as its render. If the renderer used a cement based render, it will crack like an earthquake hit it. But if they used a proper acrylic render, it'll look fine. This truly is a case where you can't always judge the book by its cover. Good luck, it's a great product. Home is where the lot is Construction commenced 3rd November 2014 Re: Hebel external aging 3Mar 19, 2015 8:57 am Check out some builders old display locations you will find what you are looking for there Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel external aging 4Mar 21, 2015 2:57 pm Hi, Rawson Homes at Kellyville has the Benham 30 in Hebel. It's been there for at least 1 yr if not more. I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5902 1 6632 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6191 |
