Browse Forums General Discussion Re: Where to get sawdust 2Feb 25, 2015 9:46 pm Try pet store if no other response comes 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: Where to get sawdust 3Feb 26, 2015 7:16 am Go to your local timber yard. They are always having to get rid of it. What do you want it for if you don't mind me asking? There is sawdust from cutting H3 -H5 timber that I wouldn't want to use owing to the chemical preservatives whereas the dust from cutting hardwood wouldn't be anywhere near as bad. Stewie Re: Where to get sawdust 4Feb 26, 2015 8:14 am Was wanting to use it to make modelling flock. Would be happy to use other material for this but apparently saw dust is the standard. Went to the local timber yard (Chatswood) but they said that they didn't have the stuff and advised that it was dangerous (although I am thinking that that may be the treated stuff). Re: Where to get sawdust 5Feb 27, 2015 10:29 am Warringah Timbers at Cromer on the Northern Beaches may be one place to look although they may tell you the same thing. If the sawdust is a light colour, chances are it is from pine and may be treated. If it is a darker brown then it is probably from cutting and planing hardwood so a lot less likelihood of preservatives being used. Stewie Re: Where to get sawdust 7Mar 23, 2015 8:31 pm Tannin in timber is what gives it its colour so anything that will affect that would be the way to go. Bleach maybe ?? Or a google search will turn up a few home cooked recipes. If the sawdust is from hardwood maybe just giving it a good soak in some water for 24hrs will leach a lot of it out. Stewie Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12662 9 24789 Congratulations! Nice to put that to bed before christmas, now you can relax 3 7173 |
