Browse Forums General Discussion 1 Feb 23, 2015 9:25 pm Has anyone built their own retaining walls? We have a relative who works at a masonary yard and has offered us 3 pallets of interlocking retaining bricks for 20 cents a brick. Have been quoted $380 per lineal metre using the same bricks so keen to do it ourselves? Do we need it checked over by an engineer during or after the process? Re: Retaining Walls 2Feb 23, 2015 9:29 pm I'd be interested in knowing the answer too 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: Retaining Walls 3Feb 23, 2015 9:47 pm Normally you will require council approval (which will mean getting an engineer to confirm the design) if the wall is over 900mm high. There is a typical detail at this link http://www.anewhouse.com.au/2014/03/blo ... loose-lay/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining Walls 4Feb 24, 2015 9:05 am 1st-timers Do we need it checked over by an engineer during or after the process? It depends on how high the wall is and where it is located Check with your Council Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Retaining Walls 5Feb 24, 2015 7:40 pm You will either need council or Private Certifier approval, an engineer can design the wall for you and then you are more then welcomed to build the wall yourself, as long as you comply with the Design specified… Although the above might not apply if your retaining wall is less then 600mm, depending on your locality…. My Advise, the money you are saving on materials, spend it towards getting someone qualified to build it…. A bricky might charge about $3.50 a brick to lay…. Re: Retaining Walls 6Feb 24, 2015 7:46 pm 1st-timers Has anyone built their own retaining walls? We have a relative who works at a masonary yard and has offered us 3 pallets of interlocking retaining bricks for 20 cents a brick. Have been quoted $380 per lineal metre using the same bricks so keen to do it ourselves? Do we need it checked over by an engineer during or after the process? Where are you located? 'It's not the size of the dog in the fight, it's the size of the fight in the dog.' Re: Retaining Walls 7Feb 25, 2015 7:58 am Handy007 1st-timers Has anyone built their own retaining walls? We have a relative who works at a masonary yard and has offered us 3 pallets of interlocking retaining bricks for 20 cents a brick. Have been quoted $380 per lineal metre using the same bricks so keen to do it ourselves? Do we need it checked over by an engineer during or after the process? Where are you located?[/quo We are on the Sunshine Coast. Re: Retaining Walls 8Feb 25, 2015 12:00 pm Check with your local council. We have existing retaining walls on both sides of our property but need to extend the retaining wall on the left hand side. We are in the Moreton bay council area and because the wall in under 1 metre in height, we don't need council approval nor do we need an engineer. You should be able to find information on your local councils website. It's a lot cheaper to do your own retaining wall than a builder!! 30/01/15 - Land Settlement 07/04/15 - Contract & colour selections 05/05/15- Council approval 28/05/15 - Site start Build Thread viewtopic.php?f=31&t=76068 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6045 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11106 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11736 |
