Browse Forums General Discussion 1 Feb 18, 2015 5:29 pm Hi All Had a new roof installed (whilst away) and the guys didn't do the best job on the final details. It is a long flat roof with side capping (not sure the term) running along it's length joining a half round gutter at the end. I would have expected that the side capping would neatly meet the the fascia and the fascia corner cover the join. The side capping would have to be folded over or cut. Not sure if this an unreasonable ask but feel that it is a bit rough as it stands... would appreciate any thoughts as to how this should look? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with roofing job - details 2Feb 18, 2015 5:39 pm Hmm, The barge capping looks terrible You should have had one custom pressed to suit rather than a stock standard wider one that doesnt suit. Generally they trim up the gutter ends. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help with roofing job - details 3Feb 21, 2015 10:48 pm That's really sloppy. It looks relatively waterproofed, but they should have spent a little more time to trim that barge. Extra few more minutes on the tin snips-I wouldn't accept this. If you needed to clean your gutters or fix your light, you could cut yourself on those raw exposed edges- so there's a safety concern too. Home is where the lot is Construction commenced 3rd November 2014 Re: Help with roofing job - details 5Mar 03, 2015 10:15 pm I like the gutters as well - lots of thought went into the choice... This photo was one of a few issues (the entire capping on the hidden boundary was not fastened to the exterior) - and rust spots on both the "colorbond" and tech screws... at 3 weeks... Re: Help with roofing job - details 6Mar 06, 2015 10:34 pm Rust spots after 3 weeks is ridiculous! What kind of rust did it look like? Were they tiny little spots? Do you notice any little metal shavings nearby? It's very common for tradies who aren't tidy to do some metal cutting and not sweep the shavings away. Moisture, heat, add a pinch of rain and you have accelerated rust! You can remove it but the longer it's left the harder it'll be to remove. The product won't collapse, but still they should be giving it a good clean! Home is where the lot is Construction commenced 3rd November 2014 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7020 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10377 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11486 |
