Browse Forums General Discussion 1 Feb 14, 2015 9:59 am Building in Eliza Ponds, Spearwood I talk about my community here: https://www.facebook.com/22suburbs Re: Anyone used/have thoughts on shadowline / ShadowSet corn 3Feb 14, 2015 9:51 pm Building in Eliza Ponds, Spearwood I talk about my community here: https://www.facebook.com/22suburbs Re: Anyone used/have thoughts on shadowline / ShadowSet corn 5Feb 15, 2015 6:59 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Anyone used/have thoughts on shadowline / ShadowSet corn 8Feb 15, 2015 10:06 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Anyone used/have thoughts on shadowline / ShadowSet corn 10Feb 16, 2015 11:49 am Building in Eliza Ponds, Spearwood I talk about my community here: https://www.facebook.com/22suburbs Re: Anyone used/have thoughts on shadowline / ShadowSet corn 11Feb 16, 2015 12:25 pm Small footprint in Eliza Ponds, Spearwood WA Re: Anyone used/have thoughts on shadowline / ShadowSet corn 12Feb 16, 2015 12:49 pm Tristanium They will need to either take the bricks up another course or drop the ceiling slightly to cover the plate - both options come with more work as they cannot simply lay the ceiling joists over the wall plate - they will need to be cut to size and fitted between the walls for each room. Even for the Gyprock ShadowSet do you think it's too late Tristan? as this shoud just effectively replace the Cove that we have already selected? Obviously I failed to mention this would be a late-ish change as we are just a plate-height brickwork now Also what do you mean about the square set skirting as standard? Building in Eliza Ponds, Spearwood I talk about my community here: https://www.facebook.com/22suburbs Re: Anyone used/have thoughts on shadowline / ShadowSet corn 13Feb 16, 2015 1:40 pm I have done a couple of quick details to try to explain this a little better. This one is how they have built it so far - and what you will get if nothing changes: So the ceiling joists will sit on top of the plate, which sits on top of the top brick. The float will go up to the top brick, but they wont take it to cover the plate as this will crack off too easily. So you need a cornice large enough to cover the gap, and also they can be quite sloppy with the ceiling lining as it has quite a high tolerance as the edges will be hidden behind the cornice. Its one of this things where the shadow set looks simple - but the clean look is much more labour intensive and harder to achieve than just covering it all up with a cornice. I am trying to find a photo on here showing the float done and ceilings in, but no cornice - and having no luck. here is one with the float done and you can see the top plate isnt covered (much) Here is what they might have to do - add another brick to retain the ceiling height or drop the ceiling height slightly to cover the top plate I am not sure if that makes it clearer - but the original option means they can be pretty sloppy with finishing off and hide it all behind a cornice. The other options mean being precise with all ends of sheet/float set, and also ceiling structure needs to be cut to fit (that would be hundreds across a build). There would be other ways to do it, this is just two options. Small footprint in Eliza Ponds, Spearwood WA Re: Anyone used/have thoughts on shadowline / ShadowSet corn 14Feb 16, 2015 1:42 pm IvyC Also what do you mean about the square set skirting as standard? Oh I just mean that they deliver homes here with the float set going down to the floor and no skirting - so you effectively get a square set finish at the base of the wall for free (where this would be an added cost for a framed home, if you really wanted it). Its just more difficult to do on the top edge in a brick build than a framed. Small footprint in Eliza Ponds, Spearwood WA Re: Anyone used/have thoughts on shadowline / ShadowSet corn 15Feb 16, 2015 1:52 pm Actually, maybe they can just dryline your walls instead of float/set - that would solve the issues..but you would need to install a skirting (if you hadn't planned to do one anyway) Small footprint in Eliza Ponds, Spearwood WA Re: Anyone used/have thoughts on shadowline / ShadowSet corn 16Feb 16, 2015 2:55 pm Depending on the builder and the cost they could just run battens to lower the ceiling 30mm or so and there is your square set or shadowline cornice. I must admit i didn't see that the OP was in WA where all ( nearly all anyway ) the homes are double brick. Stewie Re: Anyone used/have thoughts on shadowline / ShadowSet corn 17Feb 16, 2015 3:53 pm Yes, battens would be a good option at the cost of some ceiling height - but only to areas which are over 2.4m ceilings - otherwise this will drop the ceilings below minimum allowable. Small footprint in Eliza Ponds, Spearwood WA Re: Anyone used/have thoughts on shadowline / ShadowSet corn 18Feb 16, 2015 6:23 pm Do they not use metal ceiling battens anyway? I thought that was standard? At least it was 10 years ago when I was an electrician wiring new houses. The only builders that didn't use metal ceiling battens were the real bottom dwellers like Coral Homes. We'd go back to one of those houses after a year or two once the truss chords had twisted and bowed and popped screws out of the gyprock all over the place and it looked like dogs bollocks!! Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Anyone used/have thoughts on shadowline / ShadowSet corn 19Feb 16, 2015 7:47 pm 1960sModernistHome Do they not use metal ceiling battens anyway? Small footprint in Eliza Ponds, Spearwood WA The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 16404 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 48229 No. The same paint that they paint the wall with will be fine. The builder probably had every intention to paint it and not leave it black. 7 12116 |
