Browse Forums General Discussion 1 Feb 09, 2015 7:13 pm Hi all Need some advice here. The builder delivered the slab reinforcement mesh today and it looks rusty? Can rusty mesh be used for slab reinforcements? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Slab reinforcement - can rusty mesh be used? 2Feb 09, 2015 7:18 pm Surface rust is fine, it actually helps the concrete to 'grip' the steel. Loose / flakey rust is a different issue! Once the steel is in place with the correct cover (at least 40mm) no further corrosion should occur. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Slab reinforcement - can rusty mesh be used? 3Feb 09, 2015 7:45 pm Test it with a wire brush..if it's flaking it needs to be cleaned off http://www.arcreo.com.au/rust-protective-coatings Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab reinforcement - can rusty mesh be used? 4Feb 10, 2015 9:48 am I would probably question that too if I saw it. I would prefer for them to clean it off just for piece of mind. Re: Slab reinforcement - can rusty mesh be used? 5Feb 10, 2015 10:20 am Thanks for the responses, it's reassuring to know that a certain level of rust is ok. Went back to the site and had a closer look at the mesh and it's solid, not flaking just very "evenly rusted"... However, I have written to the builder and sent them a photo just so that I can have peace of mind that they know and should do something about it if it's not right. Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Slab reinforcement - can rusty mesh be used? 6Feb 10, 2015 10:31 am Hootie Thanks for the responses, it's reassuring to know that a certain level of rust is ok. Went back to the site and had a closer look at the mesh and it's solid, not flaking just very "evenly rusted"... However, I have written to the builder and sent them a photo just so that I can have peace of mind that they know and should do something about it if it's not right. Good to hear it's not flaking. I think you have taken the correct approach to this by having something in writing for future reference. Good luck with it all Re: Slab reinforcement - can rusty mesh be used? 7Feb 10, 2015 1:16 pm That photo is very exciting in many ways.. all those newly built buildings around and nearby and they have your rebars delivered ready for the slab! Very exciting! Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: Slab reinforcement - can rusty mesh be used? 8Feb 10, 2015 1:56 pm light487 That photo is very exciting in many ways.. all those newly built buildings around and nearby and they have your rebars delivered ready for the slab! Very exciting! Agreed! Can't wait till we see some progress on our build Re: Slab reinforcement - can rusty mesh be used? 9Feb 10, 2015 3:03 pm Yes, very exciting, our house is one of the last being built on that street and we can't wait! This week is supposed to have plumbing prelay and footings layed, but so far no action on our site yet! I have received a confirmation that my query has been received and the CLO will be checking with the construction manager at a meeting later today, so I will update when I have an answer Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Slab reinforcement - can rusty mesh be used? 10Feb 10, 2015 8:54 pm Update: Our builder's construction manager has had as look at the mesh and confirms that the surface appears rusty due to oxidisation and confirms that the mesh is fine to use. Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Slab reinforcement - can rusty mesh be used? 11Feb 11, 2015 5:24 am Hootie Update: Our builder's construction manager has had as look at the mesh and confirms that the surface appears rusty due to oxidisation and confirms that the mesh is fine to use. Good news. Just make sure you get that in writing. Re: Slab reinforcement - can rusty mesh be used? 12Feb 11, 2015 8:17 pm Hootie Update: Our builder's construction manager has had as look at the mesh and confirms that the surface appears rusty due to oxidisation and confirms that the mesh is fine to use. Oxidisation is rust... the steel has oxidised. That said if it is only surface rust (oxidisation), then it should be fine. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Slab reinforcement - can rusty mesh be used? 13Feb 11, 2015 9:10 pm bpratt Oxidisation is rust... the steel has oxidised. That said if it is only surface rust (oxidisation), then it should be fine. Cheers mate, yeah they confirmed that it's surface rust. Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 6515 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11611 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17880 |
