Browse Forums General Discussion 1 Feb 06, 2015 11:25 pm Hi Guys, What do you think is wrong with the laying of these porcelain tiles (600x600). Looks to be sloppy craftsmanship as compared to other work I have seen. Is it the improper laying of grout ? There is a void space between porcelain tiles ...what is missing in them ? Thanks, AB Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building with New Generation @ Heron Park, Harrisdale, WA My Build: viewtopic.php?f=31&t=70662&p=1167117#p1167117 Re: What's wrong with these Porcelain Tiles 2Feb 07, 2015 6:40 am How much is the gap between tiles. 1.5? 23/06/2014 - Paid deposit 21/07/2014 - ordered the survey and tender 13/08/2014 - soils test sample taken 14/08/2014 - survey done today 30/08/2014 - Pre-color consultant aptmnt Re: What's wrong with these Porcelain Tiles 3Feb 07, 2015 7:41 am Why isn't grout colour matching the porcelain? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What's wrong with these Porcelain Tiles 5Feb 07, 2015 9:20 am Thanks guys, yes the spacing is 1.5mm. How can the grout colour be corrected ? Thanks, AB Building with New Generation @ Heron Park, Harrisdale, WA My Build: viewtopic.php?f=31&t=70662&p=1167117#p1167117 Re: What's wrong with these Porcelain Tiles 8Feb 08, 2015 7:22 pm Have you moved in? Tilers do grout after laying. May not be done yet? What's wrong with these Porcelain Tiles 9Feb 09, 2015 2:22 pm Looks like it hasn't been grouted yet. This is a photo of ours finished should be no gaps.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Design by Greater Concept - modified version Evolution Court Build by Premiere Homes My build viewtopic.php?f=31&t=64854 Re: What's wrong with these Porcelain Tiles 10Feb 11, 2015 11:09 am I also think it looks like they haven't finished the job yet My build: viewtopic.php?f=31&t=68002 Re: What's wrong with these Porcelain Tiles 11Feb 11, 2015 12:20 pm This is what they did with my porcelain tiles. They havn't finished yet - they normally wait until the tile glue is dry before grouting. Took them 5 days to come back and grout. My Noosa 23 Build - viewtopic.php?f=31&t=72782 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10683 2 31344 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 |
