Browse Forums General Discussion 1 Feb 03, 2015 11:58 am Hi Do you have or have seen the FEG wardrobe system? We really like the look of it but have some concerns about having shelves with only rear support. We're also looking at the Lema Hangar sold by Roger Seller and Presotto Varius from Eurolife. Both are excellent but the FEG system will be much cheaper. Cheers Alex Re: FEG Walk in Wardrobe System? 2Feb 03, 2015 3:37 pm I'm sure if you contacted a distributor like Lincoln Sentry ( who provide a lot of the bathroom, kitchen and wardrobe companies with all their hardware ) then they would be able to give you some info or a link regarding maximum loading on the FEG shelves etc. A lot of those hidden fixing style shelf systems use much the same method to attach them to the walls and some of them can take a surprising amount of weight. http://www.lincolnsentry.com.au/product ... -hardware/ If you click and download the brochure and assembly instructions it should give you an insight into their system which on downloading and looking at it is more of a rail and hanging bracket than anything else. Some of their gear does look pretty swish though. Stewie Re: FEG Walk in Wardrobe System? 3Feb 03, 2015 3:48 pm Hi Stewie, thanks for the reply. I discovered the FEG system on the Lincoln Sentry website, but they couldn't be any more unhelpful. They won't give out any details of anyone or business which use the system. They can't even tell me if they have a display in any of their stores, and you can't even phone one of their stores. All the calls get redirected back to one central office. It's difficult as I've only seen photos of the system, but would really like to see it or at least find out more information before ordering it. Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3035 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4856 Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 6647 |
