Browse Forums General Discussion 1 Feb 03, 2015 11:28 am I am thinking to paint over only a tiny strip of kickboard at the bottom of my cupboard because it doesn't match with my other wall color, so I am just wondering if anyone has done something like that, painting over Laminex Silk Finish (glossy) surface? Does the paint stay on? What type of paint do you recommend? "Occam's Razor. The simplest explanation is almost always somebody screwed up." It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8267 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 |
