Browse Forums General Discussion 1 Jan 16, 2015 12:27 am Hello all. Im about to get a patio built and the builder says it has to be 1.5mtrs away from the neighbours fence. A different builder had told me it can go hard up. Its about 14.5mtrs long with steel posts. I live in Qld. Any help would be much appreciated as im struggling to find info on Google. Re: Minimum distance between buildings 3Jan 16, 2015 7:57 am Your local council development section should be able to give you a definitive answer to your question. One council may allow it, but another might not. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Minimum distance between buildings 4Jan 16, 2015 7:58 am tottenham Hello all. Im about to get a patio built and the builder says it has to be 1.5mtrs away from the neighbours fence. A different builder had told me it can go hard up. Its about 14.5mtrs long with steel posts. I live in Qld. Any help would be much appreciated as im struggling to find info on Google. It depends where you are in Qld, but if in Brisbane google search for "building setback brisbane" and there is plenty of information. If you're from somewhere else, search for your city instead. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Minimum distance between buildings 5Jan 16, 2015 8:15 am Separation distances are governed by the QDC - Queensland Development Code. That specifies, for single storey buildings, a front setback of 6m and a rear/side setback of 1.5m. If you want to go closer than that, you need to apply to your local council for a boundary relaxation also known as siting variation. Some Councils will consider it providing you have a strong argument, others wont. As others have said, contact your Local Council's Town Planning/Development section and they can give you more info as to the application process - if they allow it Dale - Building Newbie Proserpine, QLD My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6927 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5417 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15770 |
