Browse Forums General Discussion 1 Jan 15, 2015 4:45 pm Does it sound right that a builder doesn't want to investigate plumbing with a CCTV camera or do any of the drainage on a property that is defective due to slab heave? Re: Plumbing works & Slab Heave issues 3Jan 15, 2015 6:15 pm Slab Heave Recipient Does it sound right that a builder doesn't want to investigate plumbing with a CCTV camera or do any of the drainage on a property that is defective due to slab heave? No. Only reason I can think of is that they might be embarrassed by what they might find The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Plumbing works & Slab Heave issues 4Jan 15, 2015 6:24 pm We were attempting to come to an agreement on a scope of works without having to go back to VCAT ... however, it seems that the builder simply doesn't want to complete the plumbing & wants us to source our own plumbers. But would that then completely relieve any responsibility of the Builder all together or am I the only one that thinks like that? Re: Plumbing works & Slab Heave issues 5Jan 15, 2015 6:34 pm Is he simply asking you for the name of your preferred plumber or is he expecting you to bear responsibility for instructing the plumber as well? At the end of the day, he is the building professional, not you. Who is going to oversee their work? Re: Plumbing works & Slab Heave issues 6Jan 15, 2015 6:42 pm 'insider' is a professional in this field and he has stated in the post I have linked below that it is estimated that over 50% of all slab heave cases are caused by "plumbing problems". viewtopic.php?p=1243840#p1243840 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing works & Slab Heave issues 7Jan 16, 2015 3:35 pm He said that the (builder's) plumber doesn't want to do it & I should sought out my own plumber to complete the rectification works. But my concern would be that once I take on that responsibility, then I eliviate all the accountability of the builder. In fact, the fact that they dont want to pay for the CCTV to inspect the pipes is just the tip. What if that revealed a much more extensive plumbing issue that is yet to be identified...... the costs ofcourse are unasertainable. But if the plumbing works are not completed by the plumber and the 'rectification works' - and I use that term lightly, do not rectify the situation, does that just allow the builder to blame the workmanship of the plumber as he didn't do it? Just seems like there is no accountability on the builders behalf. Re: Plumbing works & Slab Heave issues 8Jan 16, 2015 3:45 pm Slab Heave Recipient, You are not a building professional and you can't oversee the plumber's rectification work. Your builder needs to take responsibility for his build and if his plumber doesn't want the job he needs to appoint one that will. Who will be paying the plumber? 12 5334 MBA and HIA both have sub contract agreements, check them out 2 7326 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4814 |
