Browse Forums General Discussion 1 Jun 16, 2008 11:46 am My parents have had an ongoing issue with their neighbour about the fence. It really needs to be replaced as it was tipping over and is also rusting, but the neighbour doesn't want to so he and my dad spent a day re-posting it etc after much discussion. Whats causing it to tip is the neighbours retaining wall. Basically the person that built there cut the slope to far. The neighbour won't fix their retaining wall properly dirt keeps coming out which is causing our paving against the fence to move, and holes to appear. If something doesn't get done soon its likely to pull the carport over (which is attached to the house). We've spoken to council and they've said theres nothing they can do.
Any suggestions of who to contact? We've had an independent report done and they've said its a safety issue. I'm in Adelaide if that helps. Re: Fencing / Neighbour Problem - Need Advice 2Jun 16, 2008 11:52 am natbut We've spoken to council and they've said theres nothing they can do. What are you talking about? This is smack bang within Councils jurusdiction. You sure you didn't talk to the work experience kid manning the phone? Re: Fencing / Neighbour Problem - Need Advice 4Jun 16, 2008 11:12 pm Which council?
Certainly sounds like something one of their departments should be addressing. Wrtite a letter with photos and if no response - try the local newspaper. Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13830 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15252 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7587 |
