Browse Forums General Discussion 1 Dec 07, 2014 1:08 pm Hi all, I will be installing a retaining wall and an agpipe behind it as shown on my sketch below. There is stormwater? pipe sticking out on the other side where the agpipe ends. Here are my questions: 1) Could I modify the current pipe sticking out or do I need a plumber (I can DIY, just concerned about the legalities) ? My plan is to stick a drainage pit on top of it and also run a pipe across and stick another drainage pit and connect it where the agpipe ends. Which leads to my next question. 2) From my brief research, I cannot run the end of the ag pipe direct to the stormwater pipe so I will stick a drainage pit as mentioned above. Am I correct? (not sure if 'drainage pit' is the correct term) I'm thinking of using the Reln stormwater pit, but i am concerned that these will be the perfect place for mosquitoes to breed. Could anyone suggest a better solution/product? This is the drainage I am planning to get: http://www.reln.com.au/Products/Nviro_Pit.aspx 3) Would I need council approval for modifying the current stormwater pipe? The pipe Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My plan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16705 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 8985 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24832 |
