Browse Forums General Discussion 1 Dec 03, 2014 6:04 pm Hi guys. I have a balcony that doesn't have a roof over it. Now the problem is when it rains the water leaks through the deck and onto my front door entrance. I don't want to spend thousands of dollars trying to fix it. I'd say 1500 is my limit as its an investment property. I can do the labour myself but after some ideas. My current idea is to use fibrocement sheets and Create a drain at one end with a downpipe into the garden below. Any advice would be appreciated Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Leaking balcony. What to do? 2Dec 04, 2014 4:38 am You will need to remove the decking boards and see what the sub structure is below this , there should be a existing drain this maybe blocked, if this is not the case you will have do a you said so you will need to create a fall to your out let this is normally done with a screed and water proofed. If your existing decking boards have just be laid on concrete I would clean this water proof the concrete ,screed and then water proof the screed, you will need to seal all the perimeter with a product like sika pro or FC11 to give a flexible joint to the brickwork. hope this helps Re: Leaking balcony. What to do? 5Dec 19, 2014 6:04 am You paint the waterproofing compound onto the cement floor ( or whatever the base of your balcony is ) with a thick coating and build it up with successive coats until it is probably a couple of mm thick to form an impervious flexible membrane. Stewie DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24148 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4784 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 3762 |
