Browse Forums General Discussion 1 Nov 30, 2014 7:48 am Hi , Property in Mount Pritchard 2170 made an offer but found this in b&p
Subfloor Finding: Retaining wall - defective Information: The retaining wall is leaning or is otherwise affected by defects. Generally this form of defect is caused by factors like poor original design and material on through to substandard construction and unmanaged stormwater flows affecting footings. Wall runs full length of front and side , 15-20m long . Anyone like to give a ballpark figure to repair? https://www.dropbox.com/s/biuckb3imzlx8q7/Ret%20wall1.jpg?dl=0 https://www.dropbox.com/s/0k3ohhhlrzaz76t/Retwall2.jpgresize%20%281%29.jpg?dl=0 https://www.dropbox.com/s/k1xpdagdhloo038/Retwall3.jpgresize.jpg?dl=0 Re: B&P Report , major defect subflooring 2Nov 30, 2014 8:16 am Hi, You image links are not working? Anything to do with sub floor will require a few dollars and also trying to find builders that will work in samll and tight areas might be a bit of a problem. 'It's not the size of the dog in the fight, it's the size of the fight in the dog.' Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11248 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5351 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10166 |
