Browse Forums General Discussion 1 Nov 25, 2014 6:49 am Hi Im building a new house with eden brae homes and they offered a steel frame instead of timber which I accepted. The walk in robe and the pantry in the house have those ugly metal wiring shelves that are brown in colour and just look downright unsightly. I was planning on building my own sheves out of timer but then I realised I would have a steel studded frame. I have seen people hang tv brackets to metal stud walls using toggle bolts but for simple shelving this looks a bit overkill as the hole you have to drill to get the butterfly clip through is massive and it looks like a pain. How would the professionals approach this anyone have any tips on what to do? Thanks Building the Sheffield 25 + 2 sq Re: Fixing wooden shelving to Metal framed house 2Nov 25, 2014 7:30 am Just use sheet metal screws like Tek screws and go straight into a metal stud. It also depends how much load you are going to hang off these screws. You can get the ones with self drilling ends or drill a pilot hole a mm smaller than the diameter of the screw. Stewie Re: Fixing wooden shelving to Metal framed house 3Nov 25, 2014 9:00 am Hi Well I guess the Walk in robe would just have clothes hanging etc but the pantry could have a fair bit of weight hanging off it with food cans cereals flour etc.... Im guessing that your talking about self tapping screws the same kind they would use to screw down colourbond sheets to a roof? The only problem is they are a bit chunky and may look unsightly after a while to wouldnt they sag in the hole especially if they were ever pulled out for whatever reasons. Cheers Building the Sheffield 25 + 2 sq Re: Fixing wooden shelving to Metal framed house 4Nov 25, 2014 10:39 am They come in all sorts of sizes with different heads. If you look at the pan head type they look no different from a round head woodscrew. http://lockeyscrew.en.made-in-china.com ... Screw.html The metal studs would be able to take a fair bit of weight no matter what screws you used ( within reason of course ). For the pantry, I'd suggest vertical supports holding the shelves anyway. By the way I wouldn't use just toggle bolts to hold up a big screen TV either. They would be going into just plasterboard. Stewie Re: Fixing wooden shelving to Metal framed house 5Nov 25, 2014 11:24 am In my kitchen reno I did about 15 years ago, I lined the walls behind the cupboards with structural plywood (the plywood is fixed to studs). This way I did not need to worry about stud locations or the studs being in the wrong location when installing cupboards. I could fix anywhere that suited the actual cupboards. Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4194 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9157 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5498 |
