Browse Forums General Discussion Re: Retractable screen - is it worth it? Thinking Centor S1 2Nov 17, 2014 5:41 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retractable screen - is it worth it? Thinking Centor S1 5Nov 19, 2014 1:40 pm Cheers Marisa http://www.artilux.com.au Screens for Bi-fold, French and Stacker Doors. 30 years experience. 7 year warranty. Free on-site consultation (Sydney) Re: Retractable screen - is it worth it? Thinking Centor S1 6Jul 01, 2015 12:15 pm Just an update - we eventually went with vertical blinds because of the cost issue - retracting screen are 2 to 3 times more expensive than vertical blinds. So far, 6 months in they are alright. There was an issue last month when the vertical blind was broken as it can't be pulled or pushed due to broken track - this seems to be an inherent problem for vertical blinds especially when you have a large one like ours with 2 meter drop and 3-4 meter span which is heavy and puts a lot of weight on the track itself. We now pull the blinds very very slowly and gently. "Occam's Razor. The simplest explanation is almost always somebody screwed up." isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73480 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 |
