Browse Forums General Discussion 1 Nov 09, 2014 2:10 pm Hello This is my first post here as I am very new to DIY. Having just popped my head into our roof space I noticed some very suspect insulation around the hot water pipe up there. I was hoping someone here might be able to identity if this is dangerous from these pictures. The house is quite old probably built in the 1930's. I would assume that this hot water pipe was installed at that time as part of it runs from the original hot water tank in the roof space. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13986 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20228 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
