Browse Forums General Discussion 1 Nov 09, 2014 3:10 pm Hello This is my first post here as I am very new to DIY. Having just popped my head into our roof space I noticed some very suspect insulation around the hot water pipe up there. I was hoping someone here might be able to identity if this is dangerous from these pictures. The house is quite old probably built in the 1930's. I would assume that this hot water pipe was installed at that time as part of it runs from the original hot water tank in the roof space. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The time to heat is purely a function of the distance between the hws and the faucet. There are many options for hot water, you can also have a circulating circuit of hot… 1 8668 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 16172 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 18087 |
