Browse Forums General Discussion Re: How to install this Paling Fence Extension? 2Nov 07, 2014 10:00 am To extend a paling fence, first you need to extend the existing posts. Then they are used to support the extension. What you show there looks flimsy, unsuitable, and doomed to failure. Have you formally given written notice to your neighbour of your intentions? You should to protect yourself legally. Re: How to install this Paling Fence Extension? 3Nov 07, 2014 5:54 pm Cut the 20cm timber on the extension back to 10cm. Sit the the extension on top of the fence with the now 10cm timber sitting down on the top rail. Knock on your neighbors door and ask if they mind you coming in and putting some screws through the 30cm timber into the top rail of the fence. Use a 75mm batten screw through the 30cm timber through the paling and into the rail. Job done That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8644 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8483 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5464 |
