Browse Forums General Discussion 1 Oct 27, 2014 8:23 pm The exterior of the back of the house is cracking. We only noticed it recently while walking home. It is a part of the house which we normally cannot see unless we are a distance away. It is a Porter Davis Brookvale home. We contacted them via email and sent in the photos and according to them, this is a painting issue and not covered under warranty. Just wanting some advice from anyone here who can help me identify what those sheets are and if they should have been primed, painted or rendered. According to house plans it says FC Sheets. The first 2 photos were taken during construction stage. FC Sheets were attached to the house in August 2009 and painted October 2009. The next few photos were taken October 2014. 5 years later and it looks like this. You can see that there are long cracks in the middle bottom of each board. The wooden parts are also flaking very badly with the nail heads rusting through and in some parts coming loose off the wall. I am hoping that someone can help me out here because this is what Porter Davis are saying to me: "I have had the new home care supervisors assess the photos, this area does require repainting. As part of home owner maintenance external painted or stained areas must be maintained by the home owner when required. Generally the weather contributes to this happening, both the sun and rain. Paint acts as a sealer/protectant for external surfaces, if this is not maintained as required, it will cause surfaces such as timber to split/flake/bow. Exterior acrylic paint has a minimum durability of 36 months and exterior enamel is 24 months." While I do not doubt that their statements are right. I think the FC sheets cracking is not a paint issue....unless the first paint job was not done properly?? Please help. Thank you!! Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 2Oct 28, 2014 7:00 am So who did the painting in the first place ? PD or you ? The timber looks like it has had maybe an undercoat and thats it. The sheet cracking looks more like structural movement. Stewie Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 3Oct 28, 2014 7:10 am I can't comment on the FC sheeting but I thought exterior enamel paint on wood had a life of approximately ten years? If they had been varnished I would have understood it but paint? Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 4Oct 28, 2014 8:49 am Hi Overwhelmed2 At a guess they appear to be tension cracks caused by sagging (unfortunately timber sags and deflect while FC fixed vertically cracks)? Do you have photos of the inside of the wall framing/roof. Do you have the original engineering drawings for the house Is there excessive deflection of the support beam supporting the wall Sorry more information is required... Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 6Oct 28, 2014 9:37 am Stewie D So who did the painting in the first place ? PD or you ? The timber looks like it has had maybe an undercoat and thats it. The sheet cracking looks more like structural movement. Stewie PD did the painting. Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 7Oct 28, 2014 10:55 am StructuralBIMGuy Hi Overwhelmed2 At a guess they appear to be tension cracks caused by sagging (unfortunately timber sags and deflect while FC fixed vertically cracks)? Do you have photos of the inside of the wall framing/roof. Do you have the original engineering drawings for the house Is there excessive deflection of the support beam supporting the wall Sorry more information is required... Attaching more photos of the construction stage. I assume this is what you mean by photos of the wall framing/roof? Are engineering drawings the contraction drawings? not sure if these are the right ones. R2 R3 R4 is the line where there are cracks happening. Next pic is the ground level and it correlates to 1B1 and 1L4 line. LOL I hope I'm making sense Thanks for the help and I hope these photos help. Re: Help please: Porter Davis 5 year old FC (Fibre Cement) S 8Oct 28, 2014 11:23 am Beetaloo Is there any indication on the inside wall (opposite the crack) of deflection/movement? Interior walls are fine. No evidence of sagging or cracking. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4501 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10241 |
