Browse Forums General Discussion 1 Oct 26, 2014 4:28 pm G'Day All, We are building on reactive clay, builder has advised we need a 1m concrete path around the boundary of the house but we would like to lay pavers on a bedding of sand, we are already getting a fair bit of concreting done for the landscaping so would like to break it up a bit and also this is something we could to so it would also save us money. In terms of run off and soaking into the ground, is paving advised as an impermeable layer around the house? There are plenty of drainage points around the slab we can divert water to. Any thoughts? Thanks in advance Sunshine Re: Concrete vs Paving - Permeability 2Oct 26, 2014 5:51 pm How about a concrete base underneath the pavers ? ... keeps the water away from the house without seeing more plain old concrete. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Concrete vs Paving - Permeability 3Oct 26, 2014 6:08 pm Sunshine2013 G'Day All, We are building on reactive clay, builder has advised we need a 1m concrete path around the boundary of the house but we would like to lay pavers on a bedding of sand, we are already getting a fair bit of concreting done for the landscaping so would like to break it up a bit and also this is something we could to so it would also save us money. In terms of run off and soaking into the ground, is paving advised as an impermeable layer around the house? There are plenty of drainage points around the slab we can divert water to. Any thoughts? Thanks in advance Sunshine Yes use a plastic as a underlay sloping away from your house preferably into a drain.If you do this you can use pavers with plastic underneath instead of concrete and it will not allow water through into your soil.Use builders plastic and I would double it over to be sure.You can run the plastic right up to the wall and seal it so even if you gutters over flow during a storm the water running down your walls will be caught by the plastic. Re: Concrete vs Paving - Permeability 4Oct 26, 2014 10:31 pm Thanks for your comments guys, i like the plastic idea! As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 4642 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 9625 |
