Browse Forums General Discussion Re: House plan with 2 minor bedrooms at front? 2Oct 10, 2014 10:46 am Depending on the size of the block, you may find that a workers cottage style floor plan is the way to go. They tended to have two minor rooms at the front of the building with a central passage between leading through to a rear family style area at the back. Best idea is to grab some graph paper from the news agent and draw the block and then start drawing the house that you want. Graph paper is great as the squares are normally to scale, such that 2 squares = 1m. Hi, Have fun, remember bedrooms should feel relaxing and inviting, the last space you see before sleep and the first you see when you wake up. Make sure it makes you… 6 16066 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 |
