Unsupervised sub-contractors
This makes me worried about other things which were not built according to plans but could not be checked because the plastering are already up.
Has anyone had this bad experience?
Yes this seems to be a problem industry wide...the secret is to rectify the problem or find a solution before the trades move on and sometimes the remedial work can be costly and inadequate.
eg. expansion and control joints can be cut in, in some cases, not so if articulated joints are required.If you post up some images and further info I'll take a quick look.HTH
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
