Browse Forums General Discussion Re: Mortar in cavity wall 5Sep 29, 2014 8:08 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Mortar in cavity wall 15Oct 08, 2014 3:31 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Mortar in cavity wall 17Oct 09, 2014 12:49 pm There are many methods which bricklayers can adopt to prevent big chunks of mortar from collecting behind the brick walls. Just google and you will see that it is not rocket science. But bricklayers get away with awful work which breach the Australian standards because clients are ignorant. And if the defects are discovered, the builders tell clients that most houses are simply built that way. Why not just abolish the entire Australian standards then? Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5646 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4582 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - Iām new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19163 |
