Browse Forums General Discussion 1 Sep 21, 2014 2:22 pm Hi all, I own a weatherboard home which has a small cellar room below it. The cellar appears to have been there for decades, but I only recently got around to going down there and cleaning out all the junk, debris and dust. Please have a look at the photos I took down there as they will tell the story. The cellar is open to the elements with a gap varying between 15-30cm across the top South and East sides. The floor is dirt with a few large pavers. The cellar dimensions approx 2000L 1600W 1800H but there is a fair bit of bowing to the timber/corrugated wall. I would like to use it as a storage space and maybe do a bit of home brewing down there. With that in mind I would like to seal up the gap at the top of the walls, seal up/cover the dirt floor and maybe insulate the walls/ceiling. I'm after ideas for a quick and simple solution for sealing/finishing the walls and floor and also the best way to close the gap between the top of the wall and the bottom of the above floor. It is dry as a bone down there, I was working in there less than a week after major storms and everything was extremely dry. The photos were taken right after I blasted it with a hose to settle the decades of kicked uo dust. So luckily I don't think I need to worry about water. I would still like to seal it from pests. I am extermely green with this kind of thing so if anyone is able to give a few pointers on the kind of techniques I should be researching for this job I would be very grateful. Thanks! (I'm new to this forum so if this is in the wrong spot please feel free to move it) Re: Sealing and finishing a pre-existing cellar space 2Sep 24, 2014 7:55 pm Any one!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Sealing and finishing a pre-existing cellar space 3Sep 24, 2014 8:03 pm Hi Hayao, welcome to the forum!! From me as a decorator....but hey since no on else has answered, here I go. I just looked at your photos, on the cheap....I would close the gape over with more corrugated iron. Get some insulation bats, place in the cavity of the walls and put more iron up over the insulation. I like the idea of the paver's, so maybe get more and top the floor with them. There you go, concealed from the elements... Good luck!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Sealing and finishing a pre-existing cellar space 4Sep 24, 2014 10:05 pm Hi Hayao From a structural point of view the bowing timber and corrigated wall should tell you that the wall isn't designed to support 1.5m of soil? The space also seems to be a bit small you may want to consider making the space larger and putting in a proper retaining wall and floor, there are various cost effective methods available. In the end it always comes down to cost, whether you can do some of the work, which method you choose,etc,etc HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7004 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1501 |
