Browse Forums General Discussion 1 Sep 17, 2014 10:00 am I'm adding a new external bathroom which butts up to the existing pitched weatherboard end wall. The frame is complete and I have just had quotes from roofers, but no one had a clear idea of how to flash against the weatherboards. I need some advice please. These photos might help. Thanks [img]Roof%20frame%201.JPG[/img] [img]Roof%20frame%202.JPG[/img] Re: Flashing pitched new roof to old weatherboard 3Sep 17, 2014 2:02 pm qebtel my advice is, learn how to post images. Fair advice, but "how to" link here is broken - viewtopic.php?f=1&t=5397 Can't do what I can't learn. Re: Flashing pitched new roof to old weatherboard 4Sep 18, 2014 1:10 pm Here's a quick " how-to " broken down into baby steps. Once you've done it a few times it is really only a few clicks of the mouse. How to embed a photo on this site... viewtopic.php?f=1&t=58434&start=20 About fourteen posts down This is for uploading a photo to photobucket. Other file hosting sites are similar. (Note: You wont see the image until you post your message/topic here on the forums). It has to be on a picture sharing website like photobucket or imgur and then you pop in the link between [img]...[/img] Stewie I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10628 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8512 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 |
